ASIO Audio device with four channel outputs
Windows10, Motu M4 ASIO drivers installed, Roon 1.7 build 710
Ethernet
USB Audio Device Motu M4
M4 has four ASIO output channels. I tested the outputs separately with an other program and got sound on on all four channels.
I like to use the roon convolver as an XO. So a Stereo signal shall be played. This goes to the convolver with its four XO filters. The Convolver file has for outputs, L/R Woofer, L/R Mid+High.
This is convolver setup:
192000 2 4 0
0 0
0 0 0 0
Cor1L192.dbl
0
0.0
0.0
Cor1R192.dbl
0
1.0
1.0
Cor2L192.dbl
0
0.0
2.0
Cor2R192.dbl
0
1.0
3.0
Looking at the device settings I can only see “Channel Layout” 2.0. There is no other selection possible. I would have expected 4.0!
Opening the “Signal Path” during playback I see:
  • Convolution Filter: 4 path, 66k taps
  • Bit Depth Conversion: 64Bit Float to 32Bit
  • Channel Mapping: 4.0 to 2.0
I guess this channel mapping prohibits output to the ASIO channels 3 and 4.
What can I do disable the “Channel Mapping” to also get output on the ASIO Channels 3 and 4?
Best DrCWO
I’ve requested the same to @brian
Would be great if it came to v1.8 next week or soon after.
See: Support for 3 and 4 channel layouts
I found a solution for my Motu M4 :slight_smile:
Solution for 4-Channel Motu M4 or focusrite audio interface and XO in a F.A.S.T configuration - Tinkering - Roon Labs Community
