I have been having these same issues for at least a week now. I am ubiquiti as well. Pleae revert so all of us can use Roon again.
Today, Roon keeps dropping connection with my DAC. Here is a snippet of the log where it happened at least once:
09/01 14:39:17 Debug: GMS: done saving nav stack
09/01 14:39:20 Info: [stats] 2102950mb Virtual, 482mb Physical, 130mb Managed, 352mb estimated Unmanaged, 1145 Handles, 39 Threads
09/01 14:39:35 Info: [stats] 2102950mb Virtual, 483mb Physical, 114mb Managed, 369mb estimated Unmanaged, 1112 Handles, 39 Threads
09/01 14:39:50 Info: [stats] 2102946mb Virtual, 482mb Physical, 107mb Managed, 375mb estimated Unmanaged, 1105 Handles, 36 Threads
09/01 14:40:05 Info: [stats] 2102944mb Virtual, 482mb Physical, 108mb Managed, 374mb estimated Unmanaged, 1105 Handles, 35 Threads
09/01 14:40:13 Debug: GMS: saving nav stack
09/01 14:40:13 Debug: GMS: done saving nav stack
09/01 14:40:14 Debug: GMS: saving nav stack
09/01 14:40:14 Debug: GMS: trying to save nav stack, but nav stack stuff was in progress
09/01 14:40:14 Debug: GMS: done saving nav stack
09/01 14:40:16 Info: [ui] [popups] Play button clicked: play_pause()
09/01 14:40:20 Info: [stats] 2102950mb Virtual, 484mb Physical, 126mb Managed, 358mb estimated Unmanaged, 1131 Handles, 39 Threads
09/01 14:40:35 Info: [stats] 2102952mb Virtual, 483mb Physical, 123mb Managed, 360mb estimated Unmanaged, 1136 Handles, 40 Threads
09/01 14:40:45 Debug: GMS: saving nav stack
09/01 14:40:45 Debug: GMS: done saving nav stack
09/01 14:40:46 Debug: GMS: saving nav stack
09/01 14:40:46 Debug: GMS: trying to save nav stack, but nav stack stuff was in progress
09/01 14:40:46 Debug: GMS: done saving nav stack
09/01 14:40:50 Info: [stats] 2102952mb Virtual, 487mb Physical, 128mb Managed, 359mb estimated Unmanaged, 1146 Handles, 40 Threads
09/01 14:41:06 Info: [stats] 2102952mb Virtual, 488mb Physical, 127mb Managed, 361mb estimated Unmanaged, 1149 Handles, 40 Threads
this is the server log, which will be more helpful, I believe:
09/01 15:14:43 Trace: [DCS Rossini] [Enhanced, 16/44 FLAC => 16/44] [100% buf] [STOPPED @ 0:00]
09/01 15:14:43 Trace: [Data Conversion Systems Ltd Rossini DAC @ 10.0.1.82:48774] [raatclient] GOT [5] {"action":"Changed","controls":{"source":{"info":{},"value":"selected","is_standby_supported":true},"volume":{"mute":false,"value":0.0,"type":"number","step":0.5,"info":{},"max":0.0,"min":-80.0}},"status":"Success"}
09/01 15:14:44 Trace: [zone DCS Rossini] Loaded Queue=8000 Tracks Swim=Inactive AutoSwim=False Loop=Disabled Shuffle=False
09/01 15:14:44 Trace: [DCS Rossini] [Enhanced, 16/44 FLAC => 16/44] [100% buf] [PAUSED @ 1:48/2:31] Mystery Lady - The Mirage
09/01 15:14:44 Trace: GetImageData[Local](id=1212619 spec=500 key=fvzqcaaa) => gotfromcache=False missinglocalimage=False didscale=True scaletime=76), overalltime=76ms
09/01 15:14:44 Trace: [Data Conversion Systems Ltd Rossini DAC @ 10.0.1.82:48774] [raatclient] SENT [8]{"request":"update_artwork","mimetype":"image/jpeg"}
09/01 15:14:44 Trace: [Data Conversion Systems Ltd Rossini DAC @ 10.0.1.82:48774] [raatclient] GOT [8] {"status":"Success"}
09/01 15:14:44 Debug: [easyhttp] [5188] GET to https://api.roonlabs.net/metadatatext/1/blobs?objectId=191:0:1434924&type=biography&sourceLangs=Rovi-albums:en,Wikipedia:en,Rovi-artists:en,Rovi-compositions:en&c=tidal-us&tidal=max returned after 54 ms, status code: 200, request body size: 0 B
09/01 15:14:45 Info: [library stats] tracks: 237531 (hidden: 19808), albums: 14792 (hidden: 1491), artists: 3977, works: 59824, performances: 118728
09/01 15:14:51 Info: [stats] 2108391mb Virtual, 6075mb Physical, 2584mb Managed, 3491mb estimated Unmanaged, 3715 Handles, 96 Threads
09/01 15:14:53 Debug: [easyhttp] [5189] POST to https://api.roonlabs.net/device-map/1/register returned after 115 ms, status code: 200, request body size: 19 KB
09/01 15:14:53 Trace: [devicemap] device map updated
09/01 15:15:06 Info: [stats] 2108393mb Virtual, 6075mb Physical, 2585mb Managed, 3490mb estimated Unmanaged, 3731 Handles, 97 Threads
09/01 15:15:16 Info: [cast] lost device CastDevice[DeviceId=Google-Nest-Mini-1ee50efbf0a7058360f65a43f2f52b67._googlecast._tcp.local, Name=Google Nest Mini, Address=10.0.1.118] because it disconnected
09/01 15:15:17 Warn: exception starting raatserver: System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host..
---> System.Net.Sockets.SocketException (10054): An existing connection was forcibly closed by the remote host.
at System.Net.Sockets.NetworkStream.Read(Span`1 buffer)
--- End of inner exception stack trace ---
at System.Net.Sockets.NetworkStream.ReadByte()
at Sooloos.RAATServer.ConnectOrStartAndWaitForExit(String path, String args, Action`1 status, ChildProcess& p)
09/01 15:15:17 Trace: [raatserver] [RaatServer JBUILT @ 127.0.0.1:9200] lost client connection. Retrying(0)
09/01 15:15:17 Trace: [raatserver] [RaatServer JBUILT @ 127.0.0.1:9200] connecting (attempt 1)
09/01 15:15:17 Info: [transport] destroyed zone System Output was playing? False
09/01 15:15:17 Trace: [zone System Output] Suspend
09/01 15:15:17 Info: [zone System Output] Canceling Pending Sleep
09/01 15:15:19 Warn: [rnet/RnetJsonClient] failed to connect No connection could be made because the target machine actively refused it.
09/01 15:15:19 Trace: [raatserver] [RaatServer JBUILT @ 127.0.0.1:9200] client connection failed. Retrying in 500ms
09/01 15:15:19 Info: [raatserver] [runner] Start or Connect...
09/01 15:15:19 Info: [raatserver] [runner] Start or Connect... C:\Users\evan\AppData\Local\RoonServer\Application\RAATServer.exe
09/01 15:15:19 Info: ConnectOrStartAndWaitForExit RAATServer, path: C:\Users\evan\AppData\Local\RoonServer\Application\RAATServer.exe
09/01 15:15:19 Info: ConnectOrStartAndWaitForExit RAATServer: Try to connect to existing raatserver
09/01 15:15:19 Trace: [raatserver] [RaatServer JBUILT @ 127.0.0.1:9200] connecting (attempt 2)
Think the problem may be related to Malware Bytes, though I have created exceptions for Roon.exe, Roonserver, and RAATServe, and RoonAppliance. Tweaking and will report.
I turned off Malware Bytes and my devices did not show up again.
I have never had malware bytes on my system which is suffering from disappearing devices….
Ever since I updated to Roon Version 2.54 a week ago, any Chromecast streaming devices vanish from the list of Audio devices after a couple of hours.
I have an Android TV which I don't use for Roon, and a Nest Audio that I use for Roon.
After restarting roonserver, the devices are back, but always vanish some time later.
My Roonserver runs on Ubuntu 24.04.3 LTS, and the device is a Google Nest Audio speaker.
roon server is on wired network, which is bridged with the Wifi network of the Nest Audio (same subnet). There is a hifiberry on the same subnet, which never causes any trouble.
This topic was automatically closed 9 days after the last reply. New replies are no longer allowed.
Is there any updates here - any solution?
@benjamin @vadim @connor @alex_h
Hello,
Since the problem appeared with the latest update, can you please provide to all an earlier version of Roon that works until the issue is resolved.
The music keeps stopping. As I write this, it’s happening every two minutes, it’s extremely frustrating, annoying, and makes Roon unusable.
I think it’s really in Roon’s commercial interest because there are probably many users who are having the same disastrous experience (even if they may not have the idea or the time to alert support).
Then, if you don’t provide an older version of Roon for download, people may simply be discouraged from using Roon (including myself, perhaps soon…)
Respectfully
Malware Bytes apparently wasn’t the problem. Was hoping for a response from Roon support here. Will wait a beat, then open a new topic or support ticket.
I feel your pain. I was looking forward to some listening over the long holiday weekend here, and Roon was completely unusable the entire time, and it remains unusable. It’s been weeks now for me at this point.
It’s really bad. Renders the program unusable. Does anyone at Roon have a timeline for a fix? Can we install an earlier version that doesn’t have this problem?
Yes please, a +1 here from me. That would be very helpful.
The last update has rendered Roon unusable for me.
A simple roll-back would at least keep me going until a fix is available.
Official forum postings with Roon Software Release Notes have lists of historical releases complete with links to the downloads BUT those links are always the same… they always just point to the latest version so they no longer download the version that they claim they do.
If you cannot give us a rollback in Roon itself then PLEASE give us a way to access the last few versions. I would still be happy to collect and send logs for a day or two to help fix issues before rolling back.
(If an expensive piece of hardware occasionally rendered itself unusable like this then people would avoid it like the plague.)
From now on I think I need to manually download and keep every release. Perhaps I can automate that.
Hi All - i agree that rolling back would be amazing. All we want is a running system.. which i had prior to 1554.
Just to throw something else in here… ive found the following which i also sent on my seperate thread - but ive added it here too as @vadim has said any future stuff will be via this thread…
@vadim - i have an interesting update. Last night i removed my ropieee raspberry pi endpoints from the network… and it hasnt errored since.. which is interesting seeing as it had only lasted a couple of hours previously.
Here is the link to my message to @spockfish last night asking him if he is aware of anything.
It would seem there is some conflict in my system with the roon server and the ropieee endpoints…
In case it is relevant…
In the RoPieee thread you mentioned the Pi display as perhaps involved here.
I don’t know for sure that my issues (playback randomly stopping and endpoints disappearing momentarily) have the same cause as yours BUT…
…I do have a Pi Display on one of my RoPieee endpoints.
So I just tried deleting ALL my Roon extensions AND shutting down the one endpoint that has a display. Two other RoPieee here do not have a display, and I have no other Roon displays anywhere.
After doing that I find that the random pausing and endpoints disappearing problem is still happening.
So at least in my case it does not appear to be related to the display.
Fingers still crossed that Roon make some progress with this issue soon.
I think mine is a different issue as i didnt have your symptoms.. but maybe they both have the same root cause…
Is someone at Roon able to give us a short, brief, daily update on this issue? About what is being done? Just so us customers know something is indeed happening? And maybe an ETA?
A response on the rollback question would be helpful too
