I received an upgrade prompt a couple of days ago. Roon has not finished loading since. I saw the posting regarding the OS issue to be resolved. I know that I might be able to rebuild with an older version but I thought the next upgrade prompt received would resolve this issue.
I just responded to the second prompt. It still doesn’t load. The timer just keeps running. Please resolve and prompt for next up-issue.
Same problem for me with 10.10.5. I’ve gone back to Build 416 as instructed. Thank you for posting the fix… One suggestion: Turning off Automatic updates requires finding the Gear icon.
The only thing to install here is the 416 client — This does not impact your database. You can install 416 without having to completely start fresh with Roon.
OK. I took it back to B416 and, after a long time, it did reload OK. I turned auto-updates off but Roon still kept prompting to upgrade which I ignored. Since doing this I am having a lot of trouble with Tidal being slow to load songs. This morning, instead of streaming to my AURALIC Vega G2, I connected my Dragonfly Red to the Mackbook Pro USB port. It did not show up in Roon so I rebooted the MacBook. It appears that Roon did it’s upgrade again now and won’t complete loading.
This just got interesting. Although all upload speeds are 20 Mbps, my download speeds for all devices on my network is 70mbps with one exception, the MacBook Pro that is running Roon. It only reaches 13.4mbps regardless of whether it is WIFI or Ethernet connected. This is likely why Tidal is slow to load on Roon although neither the Tidal app or Audirvana exhibit this issue. I know that this is not related to the B416 issue. The MacBook is late 2008 with 4 GB 1067 MHz DDR3 and a 500Gb SSD. Can anyone confirm if this is normal for a MacBook of this age?
It was left over after we all went to tablets. Up to now it has worked really well. You just can’t use DSP much but that is also true of the basic Nucleus per the description.
Right now I am using the Actiontec T3200 from my ISP/carrier. Both the MacBook Pro and my Windows 10 PC are plugged into it with 6 feet of CAT 6 cable yet the PC tests out at 4 times the download speed of the Mac. Upload speeds are identical. I’ll get it independently checked tomorrow. If that is normal for the year then it is upgrade time.
I hope, though, that the Roon update for the software issue is soon resolved even though I am really enjoying vinyl and SACD disks again. Everything else, CDs and HiRez downloads, is on the MacBook.
