The SBooster works well when a Core is used as a Bridge. I have not used the HDPlex, but I have my eye on it.
Is there any further information on Roonās LPS that was supposed to be released in 2018? Would love an updateā¦
After a lot of research I have found my candidate:
HDPLEX 200W Linear Power Supply
It seems to be the best alternative for me; just have to wait for the release
Can be used for Roon Nucleus+; Vero 4K; cable-box; and even my router if I decide to (all of them simultaneously).
FYI, my new Uptone Audio JS-2 is working nicely, at 12V.
It might work, but the big question is will it always work regardless of load? The Nucleus is requiring 19V power according to specifications.
Nice, that linear PSU is about as good as it gets.
Powering an i3 or i7 Nucleus?
A direct USB connection from Nucleus to your DAC?
Nope. 12V-19V according to manufacturer. My 7i5 has been running nicely for months now on either a 12V 100VA ZerZone, or an HDPLEX. Just make sure thereās enough amperage.
I meant nope to Tor.
@Tor_Gunnar_Burland the JS2 works perfectly with the Nucleus+ I have been running my Nucleus+ using it for 4 months now running continuously
It is very expensive. Teddy Pardo is twice cheaper and I think that the noise level is not more (probably less).
I donāt doubt that at allā¦the OP asked if the JS2 worked with Nucleus and it does
19V/10A on the HDPlex
19V/3.42A is a nice middle ground⦠it will accept 12-19v according to Intel. Lower volts means higher amps. Around 60-65W should cover the load in all cases.
This is not the first time that power is up on this forum the last time I measured my NUC7i5 and yes it will work with 12-19V and here are some figures.
I measured my NUC7i5 today it has M.2 SSD for ROCK OS and second SSD for music.
This is with regular 44.1/16 no DSP
19Vdc average 0.57A (10.83W) and peak 1.5A
15Vdc average 0.69A (10.35W) and peak 2.1A
12Vdc average 0.81A (9.72W) and peak 2.8A
Average is during play to Roon endpoint. Peak was during start up.
I have not measured amp usage during a scan for example but if all cores are being used during a library scan I suppose we can see constant use high as peak is in my test.
The peak figures in W are probably more important for someone looking for a PSU. Plus these figures will go higher than yours with multiple USB drives hanging off Nucleus.
So the safer advice is @dannyās advice of 60W+ unless someone is able to measure, like you can.
This is one of the best linear PSUās on the planet. If I had my DAC directly USB connected to my ROCKāed NUC or Nucleus, this is the one Iād be getting. 12Vdc at 5Amp continuous (60W) and 10Amp (120W) peakā¦
12-19v via its connector at the rear. 12-24v via an on board alternative connector not used on the Nucleus. Unless the specifications are different for the most recent NUC boards or you have chosen to power them differently.
@Henry_McLeod ā you are right⦠i pulled up the wrong docs.
Iām also planning to use the linear power supply for my cable box and Vero 4K. Nothing against JS2, I know it is great
But would like to get away with only one box.
I have used Teddy Pardo power supplies before mainly for Naim replacements Super cap, Flatcap and so on with fantastic susses. Can someone please let me know if this unit would suit the Nucleus itās, 19V 3.5A Power Supply
Link to the actual unit https://www.teddypardo.com/powersupplies/teddy19-3.html
Iām going to try and run the Nucleus (SOLO) and output directly to the USB DAC.
Thank you in advance M
Which connector do we need on the umbilical cable? You can choose 5.5mm/2.5mm or 5.5mm/2.1mm? No mention of this on the thread yet. Just ordered a Nucleus and have been wondering about adding a LPS, as Iāll be using the USB output.
