I have a Bonn N8 switch which feeds the Nucleus. From there another cable from the Bonn N8 goes to a Sonore opticalModule (Roon end point) which feeds via fiber optical cables a Sonore opticalRendu. The opticalRendu then feeds via a USB cable a Mytek Brooklyn Dac+. The Mytek is being powered by a Ferrum Hypos lps.
Therefore my Nucleus is acting as a streamer. Some have indicated that adding an LPS (I am considering the Teddy Pardo) will only benefit the Nucleus if it is only directly connected to a dac via a usb cable.
Based on my set up will I see a benefit using an LPS?
AceRimmer
(Smoke me a kipper, I'll be back for breakfast!)
630
A lot to read but this thread should help you with some information.
I have the volt for the Chord Qutest and sounds wonderful. I had an sbooster for the nucleus when I had it plugged directly into the Qutest and could hear the difference. Definitely think it’s system dependent. My home electrical is noisy AF.
I use a Qutest/M-scaler and a Furman 20 amp line conditioner with digital/analog out that feeds my system. The sound is good but I would like to know if your Plixir is plugged into the wall or do you have something else in front of Plixir. Thanks, John.
Ps. I use lps for my nucleus and LUMIN U1 so I’m a believer.
Speak of the devil, I have mine running into a Furman Elite 20 PFi. However, my Furman is being fed directly by my 5.2kVa Taiyo-Yuden/Xentek/Topaz .001pf isolation transformer.
That Iso xformer and Furman were present the entire time, though. OEM smps → Shanti → Plixir Elite BDC for the Qutest. OEM smps → 200VA 19V/10A R-core LPS (ChiFi) → Plixir Elite BDC 19V/4A for the Nucleus+ revA.
Just got a Hypsos somewhat based on your results. Waiting on the correct power plug as it came with the wrong one.
Wondering your current Hypsos settings for
