I have just done the same i.e. upgrade my Pro440CI to the latest firmware. Like you, I get the Roon Ready input on the amp but no RAAT output in the Roon settings that I can activate and then use.
Air is still working fine.
I connect my Devialet to my ethernet via wifi by the way.
My Roon core (macmini) also fails to see the Roon Ready networked Devialet. Airplay works fine. All by wired ethernet.
The Devialet (220 Expert Pro) can be selected to a new Roon Ready input (it nicely shows the Roon logo:grinning: , but Roon does not seem to find it.
I have tried the tips above without success.
Iâm still on a Roon trial (although I have an Innuos server arriving next week and I will be signing up), so a novice, but I followed the install instructions in the Devialet update file to the letter and everything was fine and working in a few minutes.
This is audio Nirvana - finally from source to the speakers - RAAT- canât get much better than this! Thank you to the team in Roon, you guys are making a huge impact on both hardware manufacturers and streaming services - at the end of the day good quality software development that brings joy to the person who buys these devices cannot be ignored - âRoon Readyâ is now has brand equity that is equal to the hardware the Devialet engineers have put in the box. And the results are immediate to oneâs ears!
Unbelievable development from the team at Roon the last 18 months with addition of new hardware and streaming alternative including Qubuz, MQA first decoding - I am now only seeking âRoon Readyâ solutions as that certification gives me the confidence of an audio solution that meets my need. Well done and donât let the 'naysayers" distract you from what you are guys are doing here which has taken the audio industry in the software domain 10 steps forward just in last two years - where this industry has been struggling the last two decades since he arrival of SACD/ DVD -A. Well done guys!-
Thanks Paul. I did check the blue âiâ button and it simply said âMy Devialet-ETHâ and indicated an ethernet connection. Nothing about RAAT.
Have noted a few new comments in this thread with a similar problem to mine; one also using an Apple computer to host the Roon core. But thatâs probably just grasping at straws.
@support
Are we suppose to enable Multicasting (IGMP Proxy) or not? The Roon kb and support told me to enable it, and now support says to disable it? What is it, enable or disable?
For anyone that experiences this issue, here is the rundown:
When updating the firmware, the amp said all was successful.
I did not check the actual display to confirm (pretty bad as Iâm an auditor and as we say âin God we trust, all the rest we auditâ)
After the update I had no RAAT zone in Roon
I discovered that I was running the latest firmware but DOS was still on version 2.1.0
I loaded the DOS version by entering the IP address of my Devialet in my browser, choosing the upgrade DOS option and attaching the single dos_xxxxx file from the latest firmware zip file
After the update the DOS version now displays as 2.2.4 and it also shows the wifi IP address
Followed your steps exactly Heine_Streicher. Problem solved. I am so grateful for this solution after hours of frustration and dead end advice. Thanks!
My Devialet Expert Pro 140 is still showing the âuncertifiedâ sign. Iâm running the latest firmware and OS on the Devialet and the latest version of Roon. I already rebooted ROCK twice and unplugged the powercord of the Devialet twice, but it still shows as uncertified. Also, a generic speaker icon is shown in the lower right corner instead of the Devialet amp. Any suggestions?
Iâm running ROCK on a NUC7i5BNH and conncted via ethernet.
I would recommend reaching out to Devialet for further assistance in getting your Expert Pro 140 updated. When the network firmware and DOS have been updated successfully, the device should show as âcertifiedâ in Roon.
Note it doesnât know itâs an Expert Pro 140, it just says Devialet.
@john Roon Core, ROCK and Devialet all running very latest updates, issue reported to Devialet but I am not convinced this is a one sided issue. Others, all with Expert Pro 140 and ROCK are experiencing the same issue. Please can you give Devialet a nudge to move this along.
Same problem with my 140 showing as uncertified. I also had your issue of Roon not identifying the amp as a 140. I turned it off and removed the power cord for a few seconds, reconnected the power cord and when the amp restarted Roon started showing it as a 140 so just disconnect your power cord and I think youâll fixe that problem.
So far restarting Roon, rebooting my server, restarting my 140, and reinstalling the new Devialet firmware have all done nothing to stop the amp showing as uncertified for me.
âUncertifiedâ was frustratingly persistent with my 440 too, for days. I finally powered everything down, rebooted my router, and slowly powered things back up which fixed it in my case. Also, see the post above where the Devialet DOS update didnât complete for whatever reason. Good luck.
