Windows 8.1 Professionnel (French) x64, i7-3770 CPU @ 3.4GHz 12 Go RAM
Roon 1.6 build 416 64bit
**Network Details (Including networking gear
model/manufacturer and if on WiFi/Ethernet)**
Ethernet LAN all cables category 6 or 7, gigabit switch
Ethernet connection with devialet expert 200
Hello,
I have been using roon for more than a month. It would be perfect if I didn’t have sound dropouts that occur unexpectedly at a variable frequency but about 1 occurrence per hour. The problem comes from music from Qobuz but also from music from my NAS. I am used to listening to music from other media players (qobuz desktop with Devialet AIR, MediaMonkey with monkey note, Qobuz app with apple airplay) and I have never had this kind of problem. This problem occurs randomly but I can cause it by asking to “add to library” from Qobuz. I have already tried to change the buffer size as shown on one of the attached images: not successful. I hope you will be able to guide me to solve this problem that prevents me from taking full advantage of the roon experience. Thank you in advance,
Julien
PS:
Lossless signal path
Tidal Qobuz and one folder on NAS Synology
Increased buffer size
