Meanwhile, I also was able to install Roon Remote in Genymotion, an Android emulator, and find it to work beautifully, with full Android app functionality, including metadata editing. Performance is flawless, better than on my actual Android tablet. Here’s a screen shot, but I’d be happy to upload a video screen recording if you’re interested. I have it running as a tablet in a window, but you can make it run full screen, making the experience native-like.
I briefly looked into Genymotion previously and stopped when I saw $412/year, but now I see there is a free version without support. I guess this is the way to go then, many thanks for making me look again!
With the freakin’ huge “Free for personal use” overlay over everything, light solid gray if you use the dark theme
2-finger scrolling on the trackpad does not work for me (setup issue?), just press + drag, but I have a touchscreen on the laptop that works, which might be doable
The “Free” overlay will be very hard to live with, though
OK I think I have found the showstopper: When Roon is idle, the VBoxHeadless process uses about 25% CPU in top - not great but oh well, at least no fan. However, as soon as I play music, the CPU jumps to about 130% - I suppose the notch in the progress bar. Out of the frying pan, into the fire.
Also it crashes quite a lot. Oh well, it was fun while it lasted
You mean when running the Android emulator? On my workstation, the CPU is barely working. I get very smooth operation, better than on my tablet. No crashes, either.
One thing that occurred to me with high CPU usage on Wine, is hardware acceleration. On my system, it takes a very specific combination of kernel, Xorg settings, and proprietary video drivers to get hardware-accelerated software to work properly.
Yes, when playing something in Roon in the emulator, but it’s the virtualbox process that freaks out. I was running fullscreen (and have a 4K touch display), maybe that makes a difference. Anyway, can’t be bothered because I can’t live with the overlay. But thanks in any case!
Wine: possibly, but I have a bog standard Intel graphics card and I don’t think I have a problem. Though I don’t run any games, so who knows - but I thought the Gnome compositor stuff runs accelerated anyway? And my glxgears info is fine too
I’m getting tired of this, it has become a bit of a waste of time
Not installable unfortunately from packages on Ubuntu 22.04 due to a python compatibility issue. Their latest repo is for Hirsute.
Could surely be installed from sources, but I’m not motivated because I realized that jumping to artists by keyboard in the album view won’t probably work with the Android version.
Now it hurts even more because Roon’s dark theme now looks good (not gray) in Wine under Wayland. The gray rendering was the only reason I reverted back to using Xorg when I started using Roon. Meaning it would be perfect now if not for the new CPU usage
I had the same washed out colors under Wayland up to Ubuntu 21.10. It’s what I referred to as “grey” in the post above.
Was fine under Xorg, so I reverted to that.
Recently I upgraded to the beta of Ubuntu 22.04 and the washed out colors are fixed under Wayland. Don’t know exactly which of the updates did that.
Thanks for that information. I’m currently trying Fedora as I wanted a more recent (vanilla) Gnome implementation.
However, I think I may give Ubuntu 22.04 beta a spin in a VM. It should be released by the time my new laptop arrives, which has an Intel Iris Xe GPU, so I may be fine with WayDroid.
My solution to resolve this: installation of build 898. The latest version, which did not render static booklet images at 240fps and did not do bitcoin mining in background
In linux/wine enviroment I can have 898 and latest version installed in separate directories and can compare newest version whether it was fixed or not.
Is this problem actively being looked into by Roon? This is the only way I know to control the music from a Linux machine.
I’ve got two desktop computers and one laptop, all running Pop!_OS 22.04. They all have this CPU problem. It’s especially annoying on the laptop because the fan blows all the time.
First I used the roon-on-wine script on the laptop and got the problem. This was using Wine installed from the Pop!_Shop, which is version wine-6.0.3.
Then I tried using Roon on Bottles, as I wrote up here:
With this approach, it uses wine-7.11 but the CPU problem is still there. Then I installed Wine on Bottles on my two desktop computers, and they both have the CPU problem too.
Yes but that’s exactly why they should look into it. If the controller works on Wine, they have an excuse not to develop a Linux controller themselves. If it doesn’t work well on Wine, we’ll keep on bitching about the lack of a Linux controller.
