It looks like Roon ARC is anouther victim of the so-called T-Mobile Double NAT issue. It prevented me from using Voip.com internet phones as well. Has anyone gotten it to work on the Arcadia T-Mobile Gateway, that doesn’t support Port Forwarding? Thanks!
T-Mobile Home Internet uses CGNAT (Carrier Grade Network Address Translation) and it cannot be disabled from my research online and what beta testers experienced. Not sure there is a reasonable workaround at this point.
