Roon version 1.7 build (537), roon os 1.0, iOS 13.4.1 iPad Pro .
Orbi Pro netgear SSR 60, on wifi.
Bower Wilkins formation duo, roon Ready.
Roon core is set up on nucleus rev B, try to play from my iPad to Bower wilkins formation duo.
Bower wilkins are setup and choosen. Streaming shows on roon iOS app, but no Sound comes. AirPlay do not work.
Please help.
Thank You very much in advance.
Yours faithfully
Frederik Likaj
Are you able to successfully start playback to the iPad internal speakers and the B&W are the only zone affected by this issue? Do you have the latest firmware installed on the B&Ws?
Is there any change in behavior if you try to temporarily use Ethernet?
You should also be aware that this router mode is on our list of routers with special settings needed, please see Networking Best Practices Guide:
Netgear Orbi Routers
If you’re making use of an Orbi router, we recommend unchecking Disable IGMP Proxying in your router’s settings. This setting can interfere with the ability for Roon Remotes to connect to the Roon Core.
According to the signal path, it looks like you’re using the Roon Ready output, which is good. When you are using this output, does the system work as expected, or could you please clarify what the issue is?
If the Formation Duo and Formation Audio are in the same “Room” in the Formation App setup, the Formation Audio will become the “Master” device for the zone and hide the Formation Duos from other streaming protocols. This is by design, the Formation Audio can be seen as the “Control Unit” for the Duo’s in this setup.
Is it better in terms of sound quality (or any advantages) to stream directly to formation duo loudspeakers from roon nucleus instead of streaming from nucleus to formation audio end to formation duo ( as it is the case with my settings)?
To the best of my knowledge there should be no difference in the sound quality between the two options. However, I recommend reaching out to B&W as they would be best positioned to answer this question.
Thank You for your answer.
I have contacted Bower Wilkins.
They direct me to the shop where i have bought their products.
The shop cannot tell me the answer.
I will be very pleased if You could contact Bower Wilkins on my behalf.
It is after all a roon related question to Bower Wilkins product.
Yours faithfully
Frederik Likaj
sound united has finalized their acquisition/takeover of bowers & wilkins.
‘The company owns the HEOS multi-room audio technology that could be built into Bowers & Wilkins Formation range of wireless speakers. This would inject life to a product lineup that’s been struggling to gain a foothold in the market. With HEOS onboard, B&W wireless speakers could work with Marantz and Denon audio gear to play music all around the home.’
Hi Frederik. I have a pair of Formation Duos and I plan to complete my system with a Formation Audio. Did you get any response to your question? Did you notice any difference in sound quality when Roon streams to the Audio and then the Audio streaming back to the Duos? Your help would be much appreciated as this is a very important question for me before buying the Audio.
