Nucleus plus, latest update
BT smart hub 70 meg down 10 meg up, connected by ethernet lead. one solid and one flashing green light on back of rock
bluesound node 2i connected by mesh via ethernet cable
Had power cut, since then cannot find nucleus. have factory reset router, powered on and off several times. roon can find core when moved to pc
Plus have noticed power on rock re-set after a few minutes
dylan
(Dylan Caudill)
August 12, 2020, 1:22pm
3
Hi @Stephen_Carley ,
Can you connect the Nucleus to a monitor or TV via HDMI and send us a picture of the output?
Is this a RevA or RevB?
Thanks, and apologies for the trouble.
connected to both HDMI outputs on nucleus with no output from either
ps tried a second router no difference
its the thin version, not sure if that is a or b
dylan
(Dylan Caudill)
August 12, 2020, 1:40pm
6
Thanks for checking that, @Stephen_Carley .
Was the Nucleus powered up when connected to HDMI? Was Ethernet also connected? Any change if you press the power button while it’s connected?
word ROON just appeared on screen
ethernet lead connected to router, one solid green and one flashing green light still
dylan
(Dylan Caudill)
August 12, 2020, 1:49pm
9
on my pc with pc as core yes
The smart hub manager does not see the connection from Nucleus , same on previous router
dylan
(Dylan Caudill)
August 12, 2020, 3:12pm
13
Can you send a screenshot of the Web UI?
connected to port 3. I tried several cables
dylan
(Dylan Caudill)
August 12, 2020, 3:40pm
15
Hi @Stephen_Carley — Apologies, I was referring to the Nucleus Web UI — You mentioned you could access it from your PC?
I de authorised nucleus and transferred to windows 10
so, this morning it’s working? not sure why though and will it happen again? Thanks for your help
dylan
(Dylan Caudill)
August 13, 2020, 2:43pm
19
Glad to hear it is working for you currently, @Stephen_Carley . If you see any issues return please let us know and we’ll be happy to investigate further!
Nucleus software updated this am and now roon cannot detect Roon Core, have rebooted router and Nucleus several times. HDMI screen shows word ROON
Nucleus+
Ethernet wired to BT Smart Hub
BlueSound Node 1
Nucleus software updated this AM and now Roon cannot detect Roon Core, have rebooted router and Nucleus several times. HDMI screen shows word Roon.
See my previous issue, above.
