Qobuz volume levelling issue (again) (ref#MF4JGJ)
· Something else
Qobuz volume levelling broken (again)
ISP router in modem mode, Google WiFi node acting as router, 16 port PoE unmanaged switch, Unifi access points
Further info
I have tried a good number of albums and all from Qobuz have a fixed -5dB when volume levelling enabled. Auto, Album and Track modes do this.
For ref:
Hey @Menzies-Old,
Thanks for the report! If possible, could you share a specific track name the next time you experience this? If you’re able to share a screenshot of the signal path as well, that would be helpful for the team.
We’ll be on standby for your response :+1:
Hi @benjamin
I hope you and the Roon team are doing well.
Following my report I added Tidal to check, as I previously did, that I had different VL levels and I did.
I have removed Qobuz, cleaned up and logged back into Qobuz and waited for Roon to finish adding all my fave Qobuz albums.
Some of the previously checked albums now have varying VL levels, but this is only a few. One of these is below (the only one found so far)
Still showing a fixed -5dB VL, new and older.
? Why is this a solution? It looks like a re-statement of the problem with additional data points to me.
I too find Qobuz volume levelling erratic and unpredictable to say the least.
I must have marked it as the solution by mistake
Hi @Menzies-Old,
Thanks for the examples! We’re having a tough time connecting with your Roon Server, could you please send over a set of manual logs? Here’s the link to our File Uploader. :pray:
Just to update you @benjamin I’m in the process of running a fresh installation of Roon Server. Wanted to clear up a few things.
After a fresh start I still have a -5.0 VL for all but 1 (so far) for Qobuz
I’ll upload the logs now
Menziesserver.zip
MenziesRAAT.zip
