iMac 2019 MacOS 11.3. Roon 1.8 (Build 783).
NetGear Orbi
Apple TV x 2
Project StreamBox Ultra
Audioquest Firefly DAC
Yamaha MusicCast 20 Soundbar
I have a number of AirPlay devices installed in my home and network accessible. When attempting to use these with Roon 1.8 on my iMac, the devices do not play any output. If I select the zone and track and hit play it starts to play then stops immediately. I am able to use any of these devices through MacOS with out issue. Example, I can play audio from other apps directly to those devices. All my other devices (Project StreamBox Ultra, Firefly Dac) work ok.
Excerpt from Log
4/01 09:17:01 Trace: [airplay/client] Got good OPTIONS: ANNOUNCE, SETUP, RECORD, PAUSE, FLUSH, FLUSHBUFFERED, TEARDOWN, OPTIONS, POST, GET, PUT
04/01 09:17:01 Info: [airplay] AirPlay device connected: AirPlayDevice[DeviceId=BC30D986F2CB@Bedroom Soundbar._raop._tcp.local, Name=Bedroom-Soundbar.local, Model=YAS-408, IPEndPoint=192.168.1.18:7000]
04/01 09:17:01 Trace: [airplay] connected
04/01 09:17:02 Trace: [airplay/client] Sending ANNOUNCE
04/01 09:17:02 Trace: [airplay/client] ANNOUNCE Succeeded
04/01 09:17:02 Trace: [airplay/client] Sending SETUP
04/01 09:17:02 Trace: [airplay/client] SETUP was successful
04/01 09:17:02 Trace: [airplay/client] Sending RECORD
04/01 09:17:02 Trace: [airplay/client] Record Succeeded
04/01 09:17:02 Trace: [airplay/client] Sending SET_PARAMETER volume -9db
04/01 09:17:02 Info:
–[ SignalPath ]---------------------------------------------
SignalPath Quality = HighQuality
Elements:
Source Format=Aiff 96000/24/2 BitRate=4608 Quality=Lossless
UpgradeBitDepth FromBitsPerSample=24 ToBitsPerSample=64 Quality=Lossless
SampleRateConversion FromSampleRate=96000 ToSampleRate=44100 Algorithm=HighQuality Quality=HighQuality
Truncate FromBitsPerSample=64 ToBitsPerSample=16 Quality=HighQuality
Output OutputType=AirPlay Quality=HighQuality SubType= Model=YAS-408
04/01 09:17:02 Trace: [airplay/client] Sending first sync packet rtptime=1115281042 synctime=1115369242
04/01 09:17:02 Info: [airplay] AirPlay device disconnected: AirPlayDevice[DeviceId=BC30D986F2CB@Bedroom Soundbar._raop._tcp.local, Name=Bedroom-Soundbar.local, Model=YAS-408, IPEndPoint=192.168.1.18:7000]
04/01 09:17:02 Warn: [airplay/rtsp] Exception in RTSP request: System.Exception: short read
at Sooloos.Audio.AirPlay.RTSPClient+<>c__DisplayClass16_0.b__0 () [0x00327] in :0
04/01 09:17:02 Trace: [airplay] disconnected
04/01 09:17:02 Trace: [zone] MusicCast Soundbar received transport control from endpoint integration: suspend
04/01 09:17:02 Trace: [zone MusicCast Soundbar] MusicCast Soundbar received transport control from Bedroom Soundbar: suspend
04/01 09:17:02 Trace: [zone MusicCast Soundbar] Suspend
