No pen or touch input is available for this display
Samsung Galaxy S21+
16568
I am having an issue connection to the Roon Core via remote (cell phone). I get a message that says Looking for Roon Core…I have tried turning the firewall of and back on. Any help would be appreciated. Thank you
I am having the same issue with the iOS app on iPhone 13. This is after updating the Roon core. Roon remote attempts to connect and says the app needs to be updated. There is no way to update the app.
I had to check a couple of times for the update to appear in the Play store. At first there didn’t appear to be any. It must have had to refresh it’s package sources. Just finished updating a Chromebook, Android phone, and Linux endpoint after the Core updated.
