Great job Roon team. Everything now sorted. Roon Core showing on MacBook Pro (early 2011) again and picking up my USB DAC as it should. Rock n Roll!!!
Fixed my issue. Thank you.
Since the build 903 update, all my audio devices are being ignored. My music library is gone too. In the Finder I can control Nucleus. I’m running Monterey 12.2.1 and IOS 15.2.1. Build 904 could not solve the problem. Roon worked well for two years.
Is your core on the nucleus or a mac?
I use Roon Nucleus = Core
Roon Nucleus = Core
Have you rebooted everything including your network
Great work! Works fine for me after the update!
H.
After resetting the Roon Database & Settings, Roon Nucleus works perfectly. thank you
