Settings not displaying properly or crashing [Resolved with Build 756]
‘settings display works now, using German as system language. Save the Edits not working,
But the sound is still high end.
Working fine!
One ‘problem’: the downloadable Roon version on your website is still the old one.
Hard to judge from these screenshots, but when I saw my save button greyed out like yours, it meant the cursor had moved to an empty field (not one I expected, so a bit odd behaviour) and was waiting for input.
Deselecting that field made the save button appear again.
However I agree with that the save button should not swap places between remotes.
You are correct :slight_smile:
A mouse click away from the date fields after the last tab/entry makes the save button reappear now. I can work with that …
Thanks for the quick update!
Everything works ow fine here [The Netherlands].
hi.
i have been using roon since october2020
and with the new version 1.8
i got the mentioned problem with settings
on my roon core , a lenovo i5/1.8ghz quad
16gb ram a normal pc but used as core
(settings was only displaying the general
tab)
and also a problem with my iphone8
where accessing about and display
under settings caused a crash.
I changed the display langauge i windows10pro os from danish to english us
and on the iphone8 the ios14.4 langauge
to english probably us english or uk english
an the problems dissapeared all was working
fine
then the update came (build 756)
and i installed it on my roon core
and changed the langauge in windows os
back to danish and changed the ios langauge
on my iphone8 back to danish
and restarted both machines and it was fine
with the core running (build 756)
no probems on the core
but the iphone8 running remote (build748) now in ios danish gained the problem that it chrashed when about or display was pressed under settings
now the great part.
i updated the iphone8 remote to (build 756)
and now all was good , no more problems
settings was displayed normaly without any
crashes
and both my core and remote are set to danish langage as the os and ios langauge and the langauge for roon itself set to english
my system is running good
and i think the new version i fine
but with all new things it takes time to get
to grips with and get to know well
i think roon is great.
on a closing note : i only run tidal hifi
and a few web radio stations on the system
so none of my own collection of cd’s.
have a good day
I’ve downloaded a new update this morning for 1.8 for my core and windows and the menu settings are now fully available. Well done Roon! Thanks!
The only thing I’m still trying to figure out is the Discovery function - isn’t there supposed to be a shortcut in the menu?
Go to the Home page, and scroll down the page until you see the Discover panel. The panel is clickable - so click on it to open the Discover page.
Thanks. Yeah, I am seeing “Discovery” after scrolling down but I’m referring to a direct access on the menu on the left. Wasn’t this there before with 1.7?
Yes, it’s been demoted apparently :slightly_smiling_face:
that explains problems for some. my version was not promted for “self upgrade”, I had to do manual - but as you said, downloadable version is still initial 1.8 version - with the bug
Hi Dylan tried that tip. With my iphone 12pro and various ipad Gens, it didn’t work to switch from German to English Language
It’s not the OS language, but Regional Settings that causes the issues.
Setting Region and Regional Format to anything other than US messes up the app, even though the OS is US English.
Now (with the new version of core and app) it works with languages other than English both in iOS as in Mac OS devices
Everything working fine now. :+1: :sunglasses:
Builds on the Download page should be up-to-date now.
Thanks, quick solution, everything fine now!!!
