thanks michel, but didn´t help.
Hi @dylan only set the “Regionales Format” to English (USA) and it works with any language
Crash on iPad and iPhone when scrolling fast through playlists and when choosing preferences.
Hello @El_Manu ,
Are you referring to a crash when trying to access Roon Settings , or what preferences exactly?
How many items are in the playlist that show the crash behavior?
Hello @noris,
thank you very much.
The Rock Intel NUC8i7BEH2 is connected wired to a HP 8 port switch which is connected to a fritz!box 6490. No connection issues at any time.
question: It crashes on iPad, when clicking “Einstellungen” Settings and the tab was not changed to system language “English”. Directly when accessing it.
This playlist (which is stable since changed to English iPad system Language) has 70 tracks (5 hours) of music.
Another advice I can give: When scrolling in German language of iPad, there were nice purple round shapes after the tracks. These are gone since Tab Language change to English … so these “nice” round cirkles or ellipses or so what were an error, I think.
Hope I can help solving the bug.
Here the visual effect:
Best regards
Manuel
Thanks Leon for the work-around. Both languages settings are Dutch is my case. I will see what I will do. Depends also how long it Roon takes to fix this bug.
Ich kann kein English.
Wann wird das gefixt?
@support
It is absolutely tied to the Regional format of the Windows 10 PC I’m using (OS: 19042.746 / 20H2)
using English menus etc. I even tried with different keyboard languages (English and Danish). So after some experimenting I could conclude that the following regional settings didn’t work:
But it only worked when I changed Regional format to English (United States or United Kingdom)
BUT that really ruins all the formats and decimal separators
SO the work around is to select the English Regional format when using the Roon Settings, and then change it back after you are done.
BR Jan
It’s a crap.
After automatic refresh to 1.8 the Roon never working in Win10 Pro 64 bit HU:
02/10 18:00:46 Warn: System.FormatException: Nem megfelelő a bemeneti karakterlánc formátuma.
a következő helyen: System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
a következő helyen: System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
a következő helyen: Sooloos.Version.Deserialize(String str)
I switched to english settings … the application again did not start.
Downloaded manually the Roon software and install it.
Now working … more or less … no Tidal login (from web app its working).
The playback SQ is unclassifiable, significant setback from previous version.
How can I reinstall 1.7?
How can i disable the automatic update on ROCK core and Roon application?
I have tried different language settings on my laptop (W10, German). It is sufficient if only the time format is set to English US. The settings work.
I had changed the time format directly via the old control panel (short: timedate.cpl).
Initially, the “Regional Format” remained on “Germany”; after a reboot it was also set to “English US”.
So I can confirm that the decisive setting is “Regional Format: English (United States)”.
Oltre ai problemi di sull’ IOS di iPad, perché le informazioni sugli artisti non si visualizzano con la lingua impostata all’inizio?
sono italiano perché devo leggere in inglese, il canone lo pago anche io
for me, now the only question is, how fast Roon will fix these problems. it is a shame…
Client Machine (windows 10 20H2/Intel® Core™ i7-10510U CPU @ 1.80GHz 2.30 GHz/Roon build number 1.8 )
After update 1.8 I have on my windows client problems with the Roon gui. in specific not being able to go to the settings menu, strange purple artifacts here and there (and I hate purple already)
I have added some screenshots.
overall I am happy with the 1.8 update, except for the design look and feel (too many fonts used/ mixed sizing, awful color scheme) and buggyness of windows and android client.
So please fix these issues pronto,… looks like a very cheapo release.
PS functionality is really good and elaborate, nicely done…
Patrick
worked for me, changed it to UK English and all strange behaviour disappeared.
Hi everyone!
We’ve just release an update that we believe will help here. Please give this update a try and let us know if things are back to normal!
Thanks for your patience as we’ve worked to get this fixed.
I had the same problem yesterday.
I use 10gen NUC, and usually no need to turn off HT above 7gen CPU, but I seem to turn it off
After I restarted HT, the loading speed of other information was guaranteed.
This makes me think that Roon 1.8 needs more CPU multi-core computing, after all, it will load more data.
