Sonos playback errors - "Roon lost control control of the audio device"
Build 204 seems to have solved this for me
spoke too soon - still having the same random control loss on Sonos
Dangā€¦Saw your first post this morning and got very excited. I wonder if this only impacts older Sonos devices like mine? The newest one I have is over 6 years old.
FWIW, Many of my Sonos players are more than 10 years oldā€¦with all at least 5 years old
And I can play them singlyā€¦or in Groupsā€¦or all togetherā€¦and I donā€™t have any of the issues above
Well there goes my only theory and hope of getting this resolved! :slight_smile:
The Roon core 2.04 update has made things considerably worse for me. After only a couple of these ā€œlost control of the audio deviceā€ errors over the past week, a while ago I started getting them constantly while playing Tidal to my Sonos Connect (only a year old). All songs would stop transmitting to Sonos after a few seconds, although on the Roon interface they appeared to still be playing (silently, lol.) Starting the song again resulted in the same problem. Rebooting the core and remote apps did not help. A PM with my log file has been sent to Eric at Roon, as requested aboveā€¦
Just to say, Iā€™ve been seeing the same issues - more apparent recently but that may because Iā€™ve been using the feature more. Sometimes I get a momentary drop, other times I see the message and have to press play again. Iā€™m running Roon v208, and the latest iOS version on my iPhone.
Hi @Karen_Hughes ---- Thank you for chiming in here and sharing your feedback with us. May I kindly ask you to please provide the following information:
  1. A brief but accurate description of your current setup as here.
  2. Please describe your network configuration/topology as well as providing insight into any networking hardware you may be implementing in your setup. I want to understand how your devices are communicating and what tools are being used to make those connections.
-Eric
Hi Eric,
Thanks very much for your response. Iā€™m running:
Roon 1.3 (build 208) on a 2014 iMac Retina 5K - 4Ghz Core i7 with 32Gb of RAM running macOS 10.12.3. The music is stored locally on a RAID 0 drive.
I was queuing the music from Roon Remote on iOS 10.2.1 - the version was 1.3.2003. This is running on an iPhone 7 Plus.
I was playing it through a stereo connected to a Sonos Connect, which is hardwired via ethernet (though with a 100Mb connection). I have a Sonos Play 3 as well which has been flawless - but it is wirelessly connected.
The music was a mix of ripped CDs at 44.1kHz, Apple iTunes Store purchases and 88.2kHz tracks. It seemed that the switching between the 44.1kHz and 88.2kHz was particularly prone to issues, but I did get momentary skips with the 44.1kHz files. One thing Iā€™ve still to try is forcing this onto wireless to see if it is any different.
The network is run through a Netgear R7000 - using 2.4Ghz and 5Ghz networks, but Iā€™m not sure how the Sonos works with that.
Hi Karen
Using your Roon Settings ā€”> Audio tab, you should be able to see the IP address of one of your Sonos devices, it doesnā€™t really matter which one
Substitute that IP address in place of the xxx belowā€¦and then copy the entire line into the address line of a Browser on any PC and hit return
http://xxx.xxx.xxx.xxx:1400/support/review
It may take a minuteā€¦but you will see a group of textā€¦click on the very last item called ā€œNetwork Matrixā€
Can you take a screenshot of the resulting box matrix and post it here??
Hi Ronnie,
I see the following:
ā€œLiving Roomā€ was the one having issues (the Connect). The Play 3 (ā€œKarenā€™s Bedroomā€) was working OK.
Thanks,
Karen
Hi Karen
Sounds like a weird suggestion for the momentā€¦but could you disconnect the Ethernet cable from Living Room Connect
Then try playing a similar mixed playlist of tracks as youā€™ve outlined above [if possible by using the same queue??]ā€¦and see if you have the same problems
A little while after you start playing, could you take the same screenshot as above and post it here againā€¦Iā€™d like to see if thereā€™s any major change in the mesh network connectivity as a result of removing the Ethernet cable from the living room Connect
Sorry Ronnie - I found out that the Living Room device was actually running wirelessly - my mistake. However, I switched it to wired and tried again. It all played flawlessly. Iā€™ve attached the revised matrix below.
Thanks again,
Karen
Hi Karen
Thatā€™s even betterā€¦i.e. that the Ethernet connection appears to solve the issue
Comparing the before and after from the cropped screen shots below, you can see how the Living Room in the 2nd picture below [after connecting ethernet cable] now has a ā€œGreenā€ connection to two other Sonos devices in the mesh networkā€¦meaning that data should flow much more freely to it than the yellow signal in the 1st diagram
Continue playing [if you can] for another whileā€¦and you might report back that the issues are now either gone or theyā€™ve returned
Cheers
Hi Ronnie,
Will do - and thanks very much for your help.
Karen
Hey folks ā€“ lots of Sonos improvements have gone out with the last two builds.
Iā€™m going to close this thread, but if anyone is still having issues, please start a new thread with all the details of your setup, and @support will take a look.
