Thanks for the update and for working on this so quickly!
In case it is helpful, I wanted to tell you that my Legacy 1.8 Core sees all my Sonos devices, whereas my up-to-date Core does not.
Whatās the timeframe on this as Iām experiencing buyerās remorse.
Glad this is being followed up. For me it pre-dates the Sonos 15.2 release. I had given up and just used a Chromecast audio dongle into the back of a Play 5 but that was pretty unsatisfactory for several reasons. Really hope a fix appears!
Just subscribing to this thread - first experienced this yesterday at one of my houses I hadnāt been to in a week. Glad to know itās being worked. Airplay in the meantime is just fine.
Yesterday, I had live radio via roon and airplay to a sonos one cutting out all at sudden. Donāt know if it was a one-off thing or live radio specific. I switched to the sonos app and listened to the same stream without further interruptions.
Still no connection ti my Sonos play 1 since one week. Workaround doesnāt work for me. Waiting for Roon solution
same here with 2 x Sonos 5 gen 1
Donāt forget guys, if you have S2 Sonos equipment (the exception is the Connect) you will have AirPlay as an option within Roon.
Playbar, Play:1, Play:3 and Play:5 (Gen 1) do not have AirPlay.
The following Sonos products are compatible with AirPlay:
I gave up and picked up a new Sonos Five and Two Era 100sā¦ sounds greatā¦ missed Roon. Love it
I donāt think that is quite right, the play 1 is S2 but no Airplay. Some work with S1 & S2.
With Airplay
Hi @Phil_Ryan
Youāve linked the S1 and S2 app information and devices compatible with each.
Do you refer to the Play:1 or One. These are two difference devices.
Yes Play 1: can be used with S2 but no Airplay.
Iāve just updated my old Play 1 to an ERA100 to gain Airplay in Roon
I urge you to read my post above again.
I listed Airplay compatible devices which came from the same place as your second link above. The Play:1 isnāt in that list.
The Play:1 is a S1 (aka Series 1) device but works on the S2 app.
Let me know how it sounds.
I do see the point but the first part seems to refer that S2 gives you Airplay but then you seem to quote the connect does not and others, maybe it would just be better for people to refer to the Sonos list of Airplay models?
I know the problem with āRoon lost control of the audio deviceā is nothing new since there are multiple posts related to this problem. Now Iām having the same problem any time I try to play any music through Sonos speakers. I have tried everything that has been suggested to no avail. I have also spent hours with Sonos technical and all I get is that this is a problem with Roon and not Sonos. Has anyone found a solution to this problem?
Well it took the wife three days that it was a different speaker. One might never get spotted.
Sound wise itās hard to tell as itās in the bedroom so itās never played loud, however at low volumes the bass seems more defined, iām very pleased with it.
More to the point itās been playing BBC live radio all day without any cut offs which i wanted to achieve.
I think itās either the cpu or wireless in the old units are just not upto the job of processing the live radio feeds.
Canāt connect to my audio device via Sonos stream (via AirPlay it is possible):
āroon lost control of the audio deviceā
Same Issue like here:
Configuration details:
ā¢ Roon R.O.C.K on PrimeMini with an Intel i7 and 16 GB RAM
ā¢ Remote(s): Macbook (MacOS 12.6.4, Intel i5, Roon build 1244)
ā¢ Networking details: Iām using two routers: One Router (FritzBox 7430) connected to the internet and one attached router (Linksys) to the FritzBox where the Roon Core and the Sonos Playbase are plugged-in with RJ45 cable. I use DHCP at the Linksys Router - also sometimes VPN, but the issue persists when VPN is off.
ā¢ Audi Devices: Sonos Playbase and Sonos Sub
ā¢ Library details: Qobuz streaming service, about 500 tracks as well as on local album
Iāve moved your post into the existing Support thread. Perhaps the workaround mentioned in the thread will help you.
