@dylan, see this post
https://community.roonlabs.com/t/silent-angel-vitos/90551/130?u=brianw
Edit:-
Ok, after some further checks by @Michael_Harris (thank you), it looks as though VitOS is indeed the culprit.
Edit:-
Good to know the root cause. Thank you!
So, to confirm I understand the situation correctly, my options are to stick with VitOS and not play incompatible stations, or switch to a different Raspberry Pi operating system for Roon for that zone. Please correct me if thatās wrong.
Since the zone in question is a listening room where NPR is not much on the menu, I think Iāll stick with VitOS.
Thanks again!
Tom
Yes, thatās how it seems right now, but @dylan is the expert and I hope heāll be able to find out whatās going wrong. After all, you should be able to listen to any station you like!
Roon support may be a bit busy at the moment catching up after the holidays, but heāll get there.
Cool. Please keep me posted.
May be more of a VitOS support issue, but I suspect they feel the same.
Interestingly, Iāve since switched from VitOS to Ropieee, but I still canāt get either of the WPLN streams to work. Previously, we had concluded that VitOS was unable to handle chunked transfer encoding. Not sure if that remains the issue. Suggestions welcome.
Hello again @Tom_H
Previously, you had said
Is that still the case? The XL version works but not āthe standard?
And letās try something while Iām at it⦠although there are two streams for WPLN, it is possible that Roon always picks just one if it has any problems with the other and that the one it picks is the chunked one. Iām going to temporarily stop the chunked stream. Can you try now?
Brian ā many thanks for the quick response and guidance!
Ok, and it shouldnāt have made a difference anyway as the core can successfully decode the station to PCM (because your XL works).
So thereās something about your endpoint which determines whether a station gets played or not.
This is getting beyond my pay grade. Letās ping the Ropieee guru @spockfish and see what he says.
One fact I will add in case it helps: my Roon remotes show the station loading, and they count up the seconds it has ostensibly been streaming; itās just that no sound comes out of the speakers.
Both RPi4s in question have the same outboard DAC, SMSL Sanskrit 10th, Mark IIās.
Is a reference to ā@spockfishā like a fish-shaped klieg light into the night sky? If not, please let me know if I need to do something to summon the spockfish spirits . . .
@spockfish isā¦
ā¦the Ropieee author. He will have been pinged by his name reference and will be along in due course.
So @Tom_H ,
Iāve read through the thread. Can I summarize it like this:
Is this the actual situation?
Thanks for your attention to this!
Yes, that is the situation.
I donāt know if itās related, but the same unit and associated audio zone will sometimes become invisible to Roon. It resolves when I power cycle the RPi4 and/or close and reopen Roon. The unit is always powered on, as is the DAC.
Tom
This morning I got an error message while playing a track from Qobuz: āUnexpected error on playback device.ā It tried again, generating the same message, then stopped playback.
I then rebooted the RPi4 and Roon, but to no avail. The network sees it, but Roon does not. When I try to access the device via the ālocalā site on my browser, it wonāt load.
I then unplugged the RPi4 for 10 minutes or so, and rebooted it again. This time, Roon saw it, but when I tried to play a track, it seemed to loose contact with the device, and the zone disappeared. My network still sees the device, but Roon does not.
Time to reflash?
Yep. Time to reflash.
Afterwards Iām still eager to sort out what the difference here is between āregularā and XL.
Because in the case of Roon/RAAT it should not make any difference whatsoever.
Iām back in business, although Iām completely unsure what the issue(s) were. It took me several attempts to get a stable Ropieee running on the RPi4. I honestly donāt know to what extent it might be traceable to a bad SD card, or card reader, or a network issue.
Those now seem resolved, and Iām back to where Quobuz, my own albums, and a majority of radio stations seem to work. WPLN still does not, however.
If it helps, WEVL Memphis seems to have the same or similar issue. The second-counter runs, but thereās no sound.
Many thanks for your input and general support, Harry.
Tom
But youāre back to the original situation?
Stations plays on XL, station wonāt play on āregularā?
That is correct.
Sorry for late reply, Iāve been away for a few days.
That station, and WPLN, are both single channel mono.
There may be two separate issues here - one causes silence, and the other is a station wonāt play (e.g. WDVX
). Does wdvx now play? If it does, then the reflash has fixed that and perhaps itās the mono property causing problems with WPLN. Is that possible @spockfish ?
