Can you give any insights as to the volume difference in the new 2021 presets? (The volume is significantly lower when using the LCD-X 2021 preset, than say the LCD-4 preset that you were previously recommending be used until the updated presets for the 2021 revisions were released.
Also the “More Info” link in the preset is currently a 404 error
I can confirm that for the low latency presets the gain went down by 6dB. I realize that we were overly conservative on the gain in general. You can safely disable headroom and then add 11 or 12dB gain like below (Procedural EQ->volume). For the next release I will make sure the gain normalization is done better.
It seems the volume issue is only impacting the Audeze low-latency filter (which is the default). So if you prefer that filter then the Procedural EQ is needed, another option is to just switch to the Audeze Linear filter which doesn’t have the same issue. I’m listening to the linear filter now and its quite nice.
Even with Linear, you can gain a lot of headroom with the procedural EQ, all it is doing is increasing the gain and it will not affect SQ except, your DAC or Amp will now have more headroom and will help with dynamics.
Sorry to butt in There is a thread on here somewhere about the linear filter affecting MQA playback - not doing the bit depth restore before passing the signal to the endpoint.
I can confirm this is the case for me as well.
Low latency works as expected and no issues with MQA.
To my knowledge both linear and low latency filters are processed at 64bits by Roon, then requantized to whatever the bit depth of the DAC. I don’t see bit depth being an issue, but latency could. Frankly I am surprised any DSP processing is even possible with MQA.
OK so it looks like this is impacting the chain if you are doing decoding or full hardware rendering on the DAC itself. (My Gustard X16 does this but I’m circumventing it since I am using HQ Player to upsample, I have Roon do the first unfold (decode only) and HQP take its from there). In your case I would switch back to the Low Latency Filter and add the Procedural EQ to boost the volume.
@KMan can hopefully shed some light on the technical aspects of why this may be happening to the Linear filter. Here is a link to the support thread with more details.
Hi - It seems the Linear filter is taxing the CPU and processing speeds are extremely slow <1x for DSD256 playback which makes it unusable. Changing it to low latency improves significantly. Any thoughts on if this is expected. I have Roon on an i7 NUC so more than capable of handling DSD256 with DSP applied.
This signal path is with low latency filter. Processing speed is 3x.
