15 posts were split to a new topic: Daily Mixes aren’t taking streaming service status into account
Daily Mixes are back! Thanks
Mine is working again. Hopefully the fix sticks this time. Thanks Roon devs for addressing this.
Have not seen a daily mix since the update was released. I’ve reboot the Core, reconnected Qobuz but get nothing.
Mixes are back today and are a pretty tasty eclectic mix if I may say so.
Nicely played Roon!
Happy to say mine are still here and I have saved 3 playlists today which is the best I have done so far.
Maybe try again as mine didn’t appear to be there on first open, but when I went back to Home it was there
No more Daily mixes since more than a week.
The first week was fine.
All the rest is OK.
Took a while to get Daily Mixes this morning - the Roon jellyfish(!) was wobbling for almost a minute the first time I ran up my remotes this morning, but once there my home page was very responsive and fast to load.
Michael
So out of interest I now have a completely different set of daily mixes to the one’s that came in first this morning.
I do have one minor complaint on daily mixes and maybe it’s just my setup somehow?
Some great mixes of late including some songs I really like.
So I click on that song which takes me to the album it is in.
It would be REALLY NICE if Roon told me if I already had that album in my library.
What happens is if I click the add button it just sits there spinning forever…as I have discovered because it’s ALREADY in my library.
First few times this occured I was like … WTH??
Just me or a bug or just case for a feature request?
Maybe it’s a clock/time zone/day issue in the software? Or maybe you are getting a 2 for 1 special.
Yes they must have heard me complain that I had too many good mixes to listen so sent me more of them
Running ROCK (which I never shut down) I discovered that if, on a WIN10 device, you leave a Roon control program open on the ‘Daily Mixes’ section across an update boundary and then, once that boundary has been crossed, open Roon’s Remote on an iOS device you will have 12 mixes to choose from; the day before’s mix on the WIN10 device and the current mix on the iOS device.
All good here.
Did you not sacrifice a goat and a couple chickens to the gods of Roon?
Seemed to work ok here
3 consecutive days of very good mixes
Well I just noticed that the album that the song playing is from shows on bottom left of screen, at least on my PC and if it is not in my library it will say under it “add to library”
If already in my library it does not say that so I guess it does show me if in my library already …in a fashion.
Maybe it’s because I’m on an iPad, but I don’t see “add to library” at the bottom left as you described regardless of whether or not the album is in my library.
If I click on the album cover at the lower left, the Now Playing screen comes up with the option to “add to library” whether or not the album is already in my library.
Unless there’s something I’m missing, I see nothing indicating whether or not what is playing is in my library or not.
