I run on hard-wired ethernet via Netgear Nighthawk cable/modem.
I run an optical cable from my PC’s motherboard optical out to my Yamaha RX-A3080. Roon says the signal is lossless until the last step: System output, OS Mixer, where it is listed as “high quality.”
My question is, if that signal is then relayed to my receiver with on-board DAC, is it not lossless? Or is there quality lost before it gets to the receiver?
The AV beast is where a DAC (digital signal to analog music) is needed and it has a good one. Have you tried to put the Yamaha on ethernet or WiFi and stream lossless from Roon? Chromecast should be fine.
Go to Roon → settings → audio and search for the Yam in the list. May need to be enabled. Select it then as the destination where Roon streams to and see what happens.
I had a similar experience with an Onkyo AV receiver , it only shows as Airplay… They all seem to provide multiple HDMI inputs as they are AV after all.
Is your PC close to the Amp, if so have you tried HDMI , if your sound card supports it.
Roon doesn’t seem to have any Yamaha devices on its Partners pages so the best you will get with a LAN connection is AirPlay. With my Onkyo this wasn’t even gapless !!
Does the amp have a USB input ? the picture I see doesn’t.
My solution was a Cambridge Audio CXN then Analogue RCA to the CD input of the Amp, but your AV DAC would do most of it so you are double dipping.
I would take @BeeKay advice and put a streamer in between the 2 .
A RPi with Ropieee to bridge the LAN but you may have to get a HAT (eg Allo Digione) to give a Co-ax output as a USB input doesn’t seem to be there . The Allo Digione Signature does this ready build I believe
Maybe a Bite The Bullet NUC / ROCK then HDMI to the Amp , I believe several users have done this
It does have a USB input in the front.
So, I just need a streamer?
Sorry, “Any streamer from a RPi (RoPieee, Volumio, DietPi using RoonBridge) to an iFi Zen Stream would RAAT enable your Yam.”
is all Greek to me.
You just need to use a different Audio output than system audio. There might be spfdif or realtek digital audio out which is using WASAPI and this is what you would want to use.
It’s worth a try but I suspect if you connect by Ethernet you will get AirPlay at best.
Try it and look in Settings>Audio
This is mine , my Atom is Roon Ready and Airplay also it appears twice. Your amp will probably show under “Other Network Devices” as its not Roon Ready
