Hey @Larry_Gelman,
We are truly sorry there have been only temporary improvements to the situationā¦
It looks like just yesterday the RMA team has emailed you. Did the email reach you?
Hi @beka. Yes they did. I sent out the Nucleus this morning. Thanks for you help! Larry.
A post was merged into an existing topic: Nucleus reboots randomly
@beka I am awaiting my unit to be returned from RMA. I choose not to repair the unit. Cost was almost half that of a new Nucleus.
RMA mentioned that the Ethernet port seemed loose. Not sure if that would necessarily power the unit off and reboot
Iāll see how things progress and reasses when my Roon membership expires.
Thanks Larry
Pretty maddening issue.
Good luck
I have a REV A. ~12,000 tracks. I would like to upgrade the memory. What are my options? Iām assuming it has 4gb currently? What should I upgrade it to? 8/16/32 GB? Is the only one slot?
If anyone can provide a link (from Amazon) of what I should get , would be very helpful.
TIA
This may help, although itās a later + the principle and the knowledge within should help.
Funny
I started that thread
Just put 32gb of RAM in mine
Dont notice much difference
thanks. does the regular Nucleus (rev a) have 2 slots?
were you having performance issues? Crashes?
4GB will be more than enough for 12000 tracks; hence there can not be crashes because of too little RAM. Iām confused; why upgrade the RAM ?
Not sure. I read that extra memory prevents multiple crashes?
Nothing wrong with RAM upgrade, but if your system need more memory than you got; Nucleus will crash, but this will not happen with 12000 tracks. I ran more than 150.000 tracks with 8GB; and it became iffy when doing analysis of tracks in the background while doing other heavy usage.
I upgraded my Nucleus from 4 to 8, then from 8 to 16. I did it just for the heck of it. I only have 42 local tracks.
@Jim_F . What issues were/are you having?
Not any. As I said, I just upgraded for the heck (fun) of it.
Trying not to make this a crazy thread. My Nucleus reboots randomly. I can go a week/10days with no issues. Then it will crash every few hours. I figured this would be the last attempt of a fix before i leave Roon.
Have you created a support thread regarding this with all the relevant details included?
Iām going to take a guess itās not memory thatās the issue so that might not help you much in this instance.
Yes, Yes and Yes. RMA stated that i have a bad Ethernet port problem. But obviously thats not the case.
