1.8 Audio devices in Settings but not in Zone picker [Ticket In]
Yes.
It works.
A post was split to a new topic: DietPi devices not showing up properly
Fix is therešŸ˜€
Great. Will download it now.
I’m having the same issue with Windows 10 and Hugo 2.
How can I get the newest update for Roon?
2 posts were split to a new topic: RME dac directly connected to my Zen Mini doesn’t appear in Roon
2 posts were split to a new topic: EarMen Sparrow directly connected to the core not working
(re)start the core and you’ll get a link to update…
Looks as if problems are solvedšŸ˜€
Mac mini core - Ropieee- IFI Neo iDSD
Got the updates done. It looks like I joined the list of those having the same problem
just after the fix was in. Learned some new things about using Roon in the process.
Thanks for the assistance.
I just updated to build 763. This is supposed to fix this problem.
Fingers crossed.
A post was split to a new topic: Devices not showing in Zone picker but enabled in settings > audio
A post was split to a new topic: Problem with Zones Build 763
A post was split to a new topic: Fix not working for Topping DX7s on windows 10
I just installed update 1.8 (build 763) stable (64bit) on my Windows computer and on my QNAP and Roon has detected the USB-DAC connection of my TEAC without any problem, something that it did not do before, with the previous version.
Everything seems to be working properly. Now all you need is an apology from Roon and a subscription of at least one week.
Edit: Also updated (1.8 (build 763) Roon on MacOS Mojave 10.14.6 and works perfectly on Denon PM-60 USD-DAC.
A post was split to a new topic: My WLAN Speaker looses every seconds the connection, now its not found anymore
A post was split to a new topic: Each time I restart Roon without restarting my PC there are less zones showing
After almost a day it seems that this fix works for me :slight_smile: (core on Qnap, windows and mac clients).
A post was merged into an existing topic: RME dac directly connected to my Zen Mini doesn’t appear in Roon
Hi @dylan,
I am experiencing a new issue related to missing Audio devices / zones that I have not seen for over a year. My Roon Core is running on an iMac that sleeps after 15min. (which I’m testing to see if it’s the issue). I am seeing the attached screens when I come back to the client (iOS or Windows) after a short period of time.
At least I don’t have to restart the Core which I had to do before the latest Build 763. I was also not experiencing this issue prior to the latest build, or in 1.7.
Thanks, Phil
Thanks, Phil
