Is there any diagnostic text displayed on the Roon → Settings → ARC page on Roon (desktop) or Roon Remote (Android or IOS)?
How is your Roon server connected to the T-Mobile router? Ideally it will be wired.
You say you have two Orbi mesh routers. Are both of these configured to operate in ‘Access Point’ mode? If they aren’t, and your Roon server is connected to one of these, then you may have a ‘MultipleNATFound’ error in the diagnostic text displayed in Roon → Settings → ARC.
Finally, is your service the 5G broadband service in the USA? If so, I believe it, on its own, is incompatible with Roon ARC (because it uses CG-NAT). See:
Specifically, the issue is talked about in the thread at:
One solution that is mentioned is the use of the free tailscale VPN. However, there are a couple of issues with this:
It is not officially supported and is considered tinkering - so Roon staff are unlikely to help with issues and requests for help should be made to the community in tinkering
I believe it can only be supported if you can configure your Roon Server to use the Tailscale VPN. This precludes its use with Nucleus or ROCK systems.
Thank you, Wade, for this comprehensive response. I strongly suspect I’ll need to go the Tailscale route due to the 5g Broadband T-Mobile connection. Nonetheless, here’s the error message I’m getting in the Roon ARC settings page:
The conflict in mapping entry usually means that the port chosen for ARC in Roon → settings → ARC is already being mapped to another device.
The easiest fix for this is to change the ARC port number from it’s current value to something else - say 60000.
The good news is that this diagnostic appears to make it unlikely that there is any misconfiguration of the Orbi mesh devices in your network because the gateway ip address is shown as 192.168.1.1 which is most often used by ISP routers.
I was afraid of that. Has anybody heard any developments on the IPv6 work they were doing to address these types of issues? I suspect T-Mobile’s home internet is getting quite a few users.
